If the administrator has configured this forum to support email notifications you will receive an email when your post is either approved or denied (if you have emails enabled in your profile).Return to the forum
This is annoying.
Okay, my reply to @Carolpa is online now:
The post was approved and is ready to be viewed at theURL below.Subject: Re: Roonhttps://archivedforum2.beoworld.org/forums/p/45721/330281.aspx#330281Thanks you,Moderating Team
That often happens (to me also) and has to do with some security settings on the server side.
I find it annoying too.
On the other hand we should be gratefull that the mods are concerned about the health of the forum.
And knowing that what I posted does not contain anything harmfull, I rest asure that my posts will eventually turn up in the thread.
this I wrote as answer to a question:
"Try CC on your BS2. That would be the easiest way."
it has to be moderated!
Carolpa:this I wrote as answer to a question: "Try CC on your BS2. That would be the easiest way."
Peter the Biker: Carolpa:this I wrote as answer to a question: "Try CC on your BS2. That would be the easiest way."This phrase has the “signature” of quite a few spams that had to be removed ( Try this. The easiest way)
I am sorry that I cannot reply normally. Every time I try, this message appears, see screenshot, and when my answer is finally published after two or three days, no one expects it anymore. caipiao replied on Wed, Feb 10 2021 1:24 PM Thanks @Ulrike So it's the DAC in the Node 2i that's providing the analog signal? I know you are pretty attached to the sculptural qualities of BS2 but I feel like I can hardly justify the combo lol. Quick Reply Yes it's the Node's DAC. And the Node is well hidden in a rack :)
