Beogram cd 7000 not Playing
Shawn
Posts 3
Shawn Posted: Mon, Feb 8 2021 11:13 PM
Cd player was not playing disks at all so I ordered the capacitor kit from beoparts.
The 33uf cap was completely dead so I was hopeful , but after installing the new one it still does not play at all. Does not spin.
I looked through many posts and the other main suggestion was to clean the lens, which I did,  but still no luck.
I disconnected the ribbons and pushed them back on, they all seem ok.
Anything else I can check?
Thanks!
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Tue, Feb 9 2021 7:29 AM
Will the disc rotate when you press play?
If not - will it rotate by hand?
Weebyx
Denmark
Posts 1,213
Weebyx replied on Tue, Feb 9 2021 9:59 AM
Shawn:
Thanks!
Could be one of the rubber suspensions that is broken, this will cause the disc to rest on the loader, and physically can run turn. Beoparts also has new suspension rubber for this.
Remove the front panel, and you can see if the CD units sits to low, and it is also possible to see the maybe broken suspensions.
/Weebyx
Shawn
Posts 3
Shawn replied on Tue, Feb 9 2021 4:06 PM
I checked the suspension,  it feels fine, it's still flexible anyway.
I can spin a disk easily by hand.
When I press play the laser swings into place and it moves a very small amount counter-clockwise.  Helping it move does nothing so I don't think it's getting stuck on anything.
Dillen
Posts 13,191
Dillen replied on Tue, Feb 9 2021 4:47 PM
Check your work with the capacitor kit.
Solder joints, plarities etc.
Check also for cracked solder joints on the large main board. Particularly at the regulators and connectors.
Shawn
Posts 3
Shawn replied on Tue, Feb 9 2021 5:04 PM
Polarity is definitely correct but I'll re-check my soldering.  I did all the electrolytics on the small board.
I'll also check the other things you mentioned.  Time to buy a magnifying glass I guess.
Page 1 of 1 (6 items) | RSS
