Beocenter 7002
jono
Posts 2
jono Posted: Tue, Feb 16 2021 2:06 PM
Hi All,
I just got a Beocenter 7002 from the grandma and was hoping for some advice.
When I got it the lid was stuck shut so I loosened the screws at the back and manage to free it and now its working perfectly.
The tone arm was not coming across or if it was it would touch the record and then return. I realised this was a weighting issue adjusted at the back of the tone arm.
I have got it playing by fiddling and guessing as to the correct position of the weight. Is there a "right" way to do this as I believe the needle can be expensive to replace and don't want to mess it up.
The next question I have is in regards to the buttons, when I push on one all the buttons depress as if the board underneath holding them is loose? Is there an easy way to fix this?
Is there any other maintenance that is recommended for me to do as it hasn't been used in 20+ years
To anyone that read this far thank you.Smile
Page 1 of 1 (1 items) | RSS
