Beosound5 encore N music question
mivsbai
Posts 77
mivsbai Posted: Thu, Jan 31 2013 11:10 PM
Hello,
After play with my encore for a few hours, I have had connect it to Internet, so the Internet radio function is working. However, my encore doesn't show N music function in mode. I plug both bs5e and NAS to my sky router through ethernet cables. The NAS is fine, as I can upload musics to NAS through my mac.
And my encore also shows: network connection yes, dhcp enabled, and IP address, subnet mask are all shown. However, in " mode", the N music doesn't appear, only radio, a aux and amem are shown.
I am using western digital my book live NAS, it has inbuilt twonky server, and I have enabled twonky in NAS, and store musics in flac format in correct folder in NAS through mac. Does anyone know what the problem might be? How can I connect encore to nas?
Millemissen
Flensborg, Denmark
Posts 14,680
You have to
Activate the 'Music-server function' and
"Add a NAS as a music library ...
> Use the pointer to highlight MODE.
> Turn the
wheel to select SETTINGS, and press twice the right arrow-button then GO on your music system.
> Use the pointer to highlight SERVICE SETTINGS.
> Turn the wheel to select MUSIC STORAGE and press GO.
> Select the name of your NAS in the menu. Press GO to select."
Greetings Millemissen
mivsbai
Posts 77
mivsbai replied on Fri, Feb 1 2013 11:39 PM
Hello Millemissen
Thanks for your advice. My encore is in 100% working order after I restart it, it finds nas, and everything is fine now. Thanks
Page 1 of 1 (3 items) | RSS
