hi all,
I have a bit of an issue here. I have a tv which doesnt have bluetooth output. So i brought a optic sound out supported bluetooth from logitech.
Now i have to pair this device with beosound1, how is it possible?
If the BS1 supports Google Voice Assistant, you say "Hey Google, I want to pair bluetooth", and it will open for pairing.
If it doesn't, then I assume it's like my BS2 (gen1) where you go into the B&O app and select product settings -> configure -> bluetooth
I can't help you on the logitech side.
Thanks a lot. It worked. I had to remove the beosound registered to mobile app too. Otherwise it was trying to connect to this. Then I tried the voice command, and it said error connecting and asked me to try again. Then I saw it's blue light on bluetooth and it's good
