Beogram CD 5500 noise issue
This post has 11 Replies | 0 Followers
davidosborne436
Posts 37
davidosborne436 Posted: Wed, Feb 24 2021 10:33 PM
Wondering if anyone has any ideas that might help me narrow this down. When I play a cd I can just about hear some music underneath alot of distortion and white noise.....Is the the DAC? or what else?
Thanks. Appreciate it.
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Thu, Feb 25 2021 7:20 AM
Most likely a missing voltage to the analogue stages.
Check C102/C202 for shorts and replace any burned related resistors.
If black ROE type capacitors are used, I suggest you replace all of them.
davidosborne436
Posts 37
excellent. thank you
davidosborne436
Posts 37
those capacitors look ok....anything else to check?
Dillen
Posts 13,191
Dillen replied on Thu, Feb 25 2021 8:36 PM
Look ok?
Did you check them with an ohmmeter or did you just look at them?
Yes, check that both the positive and negative supply is present at the analogues stages.
davidosborne436
Posts 37
i checked them with a voltmeter. There's the same power going thru both. I'll check the rest. Thanks. Really appreciate it.
Dillen
Posts 13,191
Dillen replied on Thu, Feb 25 2021 9:36 PM
Power going through them?
davidosborne436
Posts 37
yep
davidosborne436
Posts 37
yes. tried pushing all connectors in. I can just about hear some music under the white noise
Dillen
Posts 13,191
Dillen replied on Fri, Feb 26 2021 7:19 AM
You don't measure power with an ohmmeter.
You measure resistance. And it should of course be done with the CD player unpowered.
What are the readings across the two capacitors I mentioned?
Are both the negative and positive supply present at the analogue stages (player powered)?
Voltage readings?
davidosborne436
Posts 37
10 ohms for each capacitor.
can you help with where to measure the analog stage please? I'm new to this...
Sweden
Posts 43
Martin replied on Thu, Mar 18 2021 4:58 PM
Hi!
Maybe you have a similar issue that I faced with my Beocenter 9500 CD which I just found out was caused by the DAC.
https://archivedforum2.beoworld.org/forums/p/46078/333530.aspx#333530
Locate the TDA1541A DAC chip and try to cool it with electronic freeze spray or just press a small heat sink against it to see if the sound/noise changes. If it does, in any way, you could try to replace the DAC.
Page 1 of 1 (12 items) | RSS
