Hello
in the user guide to the above television it states the following
If you disable the TV tuner or DVB tuner, you can activate a connected peripheral unit with the TV or DTV button.
... does anyone know if it is possible to use the TV button to switch a HDMI input on for my Apple TV?
thanks
If your BV7 is updated to match what is in the above description, the commands/buttons on the Beo4 can be ‘freed’ for activating any connected device
This is done in the settings, when you configure the BV7 for the additional, external source and should be fairly easy to see there........once you have disabled the tuners.
I still use DTV but have the ATV connected to one of the two spare HDMI slots. Use V-MEM command on Beo 5 remote and then ATV remote to navigate.
