Hello all,
I have recently inherited a Beosound 9000 (I believe MkIII). It was someone's who sadly passed away.
I have switched the unit on and noticed a few problems:
On a side note, when the stereo is switched on, the red light flashes from the very start. Is this normal or should it not be flashing.
I should also add that is has been in storage and not played for over 12 months.
Thanks for your help in advance. I hope i can fix the issue. Or do you think it's only good for the scrap heap?
Thanks again,
Phil
Thanks. I've tried adjusting the arrow and cleaning, but it still struggles to open the door...I think a trip to a b and o engineer is needed...sounds expensive before I've even walked in the shop
Thanks. I've tried adjusting the arrow and flipped it vertically and the door opens....so now it's the buttons on the top and the CD resetting itself..but you would guess it's a laser problem?
I turned the stereo vertically and it fixed the door opening...the only reason I question the laser is because it plays perfectly for a minute or two then resets...could it be a cpu issue?
Your BS9000:
1. Needs a new belt for the glassdoor.
2. It's pincode protected. Needs a pin every time the power is taken off. Find the pincode or get a master code (with prove that it is yours) at a dealer, who can provide you with a master code.
Thank you..I had my suspicions that this may have been the case
