We have a problem with our Beogram CDX player. When you press the eject button the unit lights up but won't open.
I managed to get it open manually - the motor worked once the lid was slightly lifted and closed properly.
It managed to play a cd although we had to press the lid a bit before it properly read the CD.
Any idea's what's likely causing the issue? Or is it best getting it repaired?
It can be caused by one or more of three things:
1) The two black dots under the lid tend to get sticky and then they hold the lid. Best is to remove them. Some say the dots underneath a Beolink 1000 can be used but I have never tried that.
2) The gear wheel is worn and needs replacement
3) The position switches is damaged and needs replacement
/Pindsen
