Hi everyone
I’m planning to purchase a beosound moment and connect it to my BV 11. My question is- is it possible to connect the BSM to the BV 11 wirelessly?
thank you for you help.
Quick answer. If BS Moment and BV11 are connected to the same router you can chose BV11 as speaker for the BS Moment. By that they are connected together and behave as 1 system. I guess you need to make some settings in the BV11, at least that is necessary for the Android based BVs.
BS Moment can be connected wirelessly to internet, but my experience is that it is much more stable wired connected.
I agree, if possible always use the wired connections!
That said, if your wifi is stable, this also is possible.
You will have to integrate the two systems - after that they basicly work as one system.
The sources of the Moment appears in the source list on your BV11 - the tv powers up, when you start to play from the Moment etc...
Thank you very much I have seen that link on my BV. I will try wire connection. I hope BSM won’t cause me problems, I saw loads of people complaining about it. thank you
