Beogram 1700 - 33 RPM Speed / Weight imbalance issue?
uktexan
Posts 3
Silver Member
uktexan Posted: Mon, Apr 19 2021 1:02 AM
Having a weird issue to track down with my Beogram 1700. Every time, and I do mean every time I try to play a 33RPM record, the speed is incredibly fast (I don't have a 45 laying around, but it feels faster).
I searched here and found a number of threads talking about switching out the belt, which I did. But no change. I do have a theory though!
It seems it has something to do with the weight? If I put on an old album that's super light, the only way I can get a consistent (correct) speed is by adding 2-3 similar albums underneath. If it's a more modern 180 gram album, I just need 1. Even doing this, I still go into hyper-mode the first time, but once I pause and restart, it works for the entire side every time.
If I have to pause before flipping sides, it again goes into hyper-mode on restart, every time.
I am grateful that I can at least get through an entire side without it switching speeds every song (which it did every time before), but I'm hoping anyone has some advice so I don't have to keep stacking albums.
Thanks all!
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Mon, Apr 19 2021 6:23 AM
Is the belt slipping on the motor pulley?
Did you fit a correct belt or something from ebay etc. that merely looks somewhat right?
Did you replace the speed setting trimmers?
Did you replace the capacitors?
Check for cracked solder joints at the PCB?
Parts here : Beoparts-shop
uktexan
Posts 3
Silver Member
uktexan replied on Mon, Apr 19 2021 10:49 PM
I got the belt from a local repair shop in London before I moved away. I can't tell for sure obviously (should've bought from you), but it does appear visually to not be overly tight or have too much slack (and when I run the unit without the top platter, I don't see evidence of slippage).
No solder joints seem decayed, but what about the speed trimmers? What exactly are they? \
Thanks so much Martin.
Dillen
Posts 13,191
Dillen replied on Tue, Apr 20 2021 6:43 AM
The trimmers are the electronic components that allows you to set (fine-adjust) the speeds. Certain types are known to fail due to age.
They are included in the servicekit
Place a finger on the motor pulley as a brake, and rotate the subplatter by hand. Note if the belt slips around the motor pulley. It should have a fair amount of friction.
But, with all due respect, unless specifically working with B&O it's very unlikely that any local repairshop will have anything but standard belts.
Page 1 of 1 (4 items) | RSS
