Hi there,
Im pulling my hair out - my Beoplay A8 has started playing up recently, it's never been perfect but now i struggle to connect via my iPhone XR, it barely shows up on the Airplay and when it does will be unable to connect. When it does finally connect, it will play for about 10 mins then disconnect.
I tried docking my iphone, which sometimes connects and when it finally does will play for about 5 minutes and crashes, literally like a broken record and i have to pull the phone out.
Connecting via iTunes on my PC helps a little but still drops out after about 30 minutes.
I've tried doing a factory reset, and since connect via LAN Powerline - which hasnt made any difference.
Any help would be much appreeciate - many thanks!
