Hello all,
My Beocord 5500 part of my beosystem has stopped working.
Is there anyone in the Greater Manchester area of the UK that could look at it for me?
Many Thanks
Jon
Hi Jon,
when you say it’s stopped working, a little more detail would be great. If it needs belts Martin ( Dillen ) is your man.
Keith
Hi Keith,
Its acting like theres no power. Tried the obvious like changing the plug fuse but it acts as if it's not plugged in.
Are there any tell tale signs I can look for?
Happy to pay someone for quote/repair if necessary
Check the internal fuse.
Thanks Keith, is that relatively easy to do?
zoomerlon: Thanks Keith, is that relatively easy to do?
Yes, - if you know how.If you don't, I suggest you leave it to someone who does.
