Beogram 1902 tonearm wiring - repair? replace? bin?
This post has 3 Replies | 0 Followers
pfabian
Posts 3
pfabian Posted: Sun, May 9 2021 12:52 AM
Good evening,
I've recently been lucky enough to get into a position where I could finally start getting some vintage Bang&Olufsen gear into my life (if it's worth getting something - it's worth getting something beautiful), via various means. I'm happy to say most of the things I got just need some love, though they've got here in various stages of "untested" and "not working".
One of these is a Beogram 1902, which I've found has a dead channel. I've diagnosed it down to wiring in the tonearm.
What I'd like to ask - is it possible to repair the wiring, or replace the tonearm as a whole part?
Or should I just write it off and see what I can recover from the rest (looks like I can recover basically the whole cost just from the MMC4000 cartridge...)?
I'd really prefer to put it together, but maybe some battles are just lost.
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Sun, May 9 2021 9:24 AM
You can take off the cartridge socket and inspect.
Its held by a small screw at the underside of the tonearm.
pfabian
Posts 3
pfabian replied on Mon, May 10 2021 1:58 AM
Thanks. I've managed to unscrew the bottom and disconnect the chassis ground (?) connection
The bit with the upper connections seems to be well stuck in there. I'll see if I can get it out without breaking the plastic.
Dillen
Posts 13,191
Dillen replied on Mon, May 10 2021 7:20 AM
If it's glued in, you may have to stick it into warm (boiling water) for a moment to losen the glue, but I don't think it is glued in this model.
Page 1 of 1 (4 items) | RSS
