I have a Beomaster 4400 which has started emitting a crackle in the left channel. The crackle lasts only a few seconds and happens between 30-40mins after being switched on.
It does it on multiple sources and regardless of whether anything is actually playing at the time. I've tried swapping speakers and cables so can rule these out.
Otherwise it sounds incredible and there is no noticeable change in performance after the crackle.
Any ideas?!
