MCL2P
This post has 4 Replies | 0 Followers
graemeben
Posts 132
graemeben Posted: Wed, Feb 6 2013 4:03 PM
Hi everyone.
Quick question please. is the MCL2P amp ok to use with a Beosound 3000 to drive passive speakers or do I need anything else with it? Whole system will be in the same room, so no extra speakers etc being driven in another room. Do I need an extra ir receiver or just a power link cable? (Sorry that's more than 1 question..)
Thought I would ask you knowledgeable people before parting with my hard earned cash.
Thanks.
Graeme.
kallasr
Germany
Posts 2,562
kallasr replied on Wed, Feb 6 2013 4:19 PM
Just the mcl2p with a mk2 fully wired powerlink cable. Turns on with the beosound. I used this for some time.
Ralf
olvisab
Posts 1,391
olvisab replied on Wed, Feb 6 2013 4:21 PM
Hi Graeme,
If you use the beosound and the speakers in the same room, you just need a powerlink cable, but beware, the powerlink must be a MK2.
You can order one to Steve from soundsheavenly, you won't have any surprise.I met someone who ask for a MK2 to his local b&o dealer and the cable didn't work at all.
Best regards
oLivier
4 beolab 5,  beolab 9, beolab 10, beolab 5000, beolab 8000 mk2, beolab 6002, beolab 3500, beovision 7 55 mk2,  2 beovision 11 46 mk4, beotime, beosound ouverture, beosound essence, beoplay A8, beomaster 900 RG de luxe and the collection continues...
graemeben
Posts 132
Thanks everyone. Wasn't sure if I needed any extra receivers.Mk2 power link came with the Beosound 3000 thankfully.
Thanks again for advice.
Graeme.
Guy
Warwickshire
Posts 2,590
Guy replied on Wed, Feb 6 2013 8:15 PM
You may find that the 'mute' function doesn't work - it doesn't for my son's BC2300 in a similar set up.  I raised a thread about it a while back and apparently there is no internal muting in the MCL2P:  http://archivedarchivedforum2.beoworld.org/forums/t/35573.aspx
Page 1 of 1 (5 items) | RSS
