Hi All,
This has been driving me crazy for a while. I must be missing something simple.
How do I initiate an AV like command so I can, watch the stock market or the footy on the TV and play a music or radio source at the same time? I use NL and ML music sources and everything is linked via a NL/ML converter.
In the past the CD, A.MEM/A.Tap etc commands, just needed a proceeding AV command to use this feature. Unable to find AV on the new remote.
Thank you, Beoaus.
You didn't missing something. With BV Avant (NG) and BV11 (and higher) it isn't possible to use the AV command! I miss it also!
I am flabbergasted, are you serious?
Surely, there must be a way...
