Hi
Is there any real difference if my Pentas are connected to an Audio or Video Master - i.e. BS3000 or Avant?, I ask as the BS3000 is in another room so moving it would involve getting longer cables, moving the aerieal and AE to which it is all connected. Before I do this or experiement, just wondered if anyone had tried it and noticed any difference. I know I did notice a difference when had a BV7000 and BC9300 in that it was better through the 9300.
When I had my 7000 system and Avant, I thought they sounded better through the 7000. However kept them through the Avant as this was the only way to get surround. Now have BC2 and speakers attached to BV5. BC2 is not as good as the 7000 system!
Peter
Thanks Peter - I think I will have to give it a go and see - I live in a flat so usually have the Avant on Speakers 1 anyway.
