New forum
Opman
Wilmslow, Cheshire
Posts 443
Opman Posted: Thu, Mar 15 2012 9:56 PM
Hello All
I'm really struggling to get to grips with the new forum.
Firstly how do I select only English? Every time I select it in the drop down menu at the top of the page and look at a thread it reverts to all languages :-(
When I use the back arrow I get messages saying something like the page has expired or that the script cannot be displayed.
I use Firefox if that helps any one to answer my questions.
Regards
Opman
Peter
Earsdon
Posts 11,991
Peter replied on Fri, Mar 16 2012 8:23 AM
I think the problem is that you are using the Active Topics box to browse in. Scroll down and just pick General Discussions if you want to avoid other forums. The system is much the same as it was before but the Active Topics box is new. I just use that and ignore those I don't wish to read. You can expand the Active Topics box by pressing more at the bottom of the box.
Peter
Opman
Wilmslow, Cheshire
Posts 443
Opman replied on Fri, Mar 16 2012 11:20 AM
Hi Peter
Thanks for the tip. I was used to just logging straight into the forum. I now know that I have to scroll down to select General Forum.
Regards
Opman
Page 1 of 1 (3 items) | RSS
