Can someone tell me how to remove the fabric front covers on My Beovox and Belolab Pentas.
From a couple of the poor quality photos I have seen of the clips, it looks like they pull stright towards you if you at the front. I have had a "pull" on them but I'm worried to pull too hard as they are old and I don't want to snap anything. I also don't know where to grab! Or do you lever them off?
Many thanks
Stoobie
here is a YT video .... of your own risk ....
https://www.youtube.com/watch?v=P3rd3NTQ-iM
good luck
That's exactly what I needed.
Thank you
Thank you Beozip - All worked fine and so easy when you know how.
