Adapter needed? Connecting beolink to splitter
davelarue
Denmark
Posts 98
davelarue Posted: Sat, May 29 2021 6:47 PM
I have an airport exp connected to my beolab 9s, but only on speaker is playing.
The white beolink is connected from the first to the second speaker.
i guess i need to connect the second cable from the splitter directly to the second speaker? If so, is the an adapter from ‘he’ to ‘she’?
Thanx. D
https
https
Steve at Sounds Heavenly
The cable workshop, Leics, UK
Posts 2,165
The white cable is not needed - the blue cable in your picture has two plugs, one goes directly to each speaker.  The blue cable splits apart to allow the speakers to be placed as far apart as required.
If you already have the white cable in place between the speakers (eg. inside a wall), then you can add this coupler to link the plug from the blue cable to the plug of the white cable to reach to the second speaker:-
https://soundsheavenly.com/bang-olufsen/148-powerlink-compatible-barrel-adapter-for-extending-cables.html
Kind regards, Steve.
Steve.
www.soundsheavenly.com
davelarue
Denmark
Posts 98
davelarue replied on Sat, May 29 2021 8:14 PM
Thanks Steve. I’ll order it๐Ÿ‘๐Ÿผ
Page 1 of 1 (3 items) | RSS
