Hi all,
I just bought a very nice MX7000 and I expected its audio to be its best part but I hear some nasty clipping from different sources (Nintendo Wii via RGB PAL SCART, for example).
Is there a way that I can use to test if the defect is on the TV side?
What do you do to test the TV audio system in a safe way?
Should I replace caps?
Is there anyone in the Netherlands doing this?
Thanks for your help.
