Changing harddisk at Beosound 3200
This post has 0 Replies | 2 Followers
Marcel
Eindhoven-Netherlands
Posts 10
Marcel Posted: Fri, Jun 18 2021 4:31 PM
Hello,
I have some questions concerning changing the original harddisk from my Beosound 3200.
1. Can i replace this original harddisk to a ssd sata which will be connected at a ide 40 pins to sata converter and yes;
2. will there be enough space left to build this converter and ssd into my BS3200?
3. Is opening the BS3200 an easy operation?
4. Is there any document that shows/explain me how I can open the BS3200 to get acces to the harddisk?
I know I probably also have to clone the original IDE harddisk to the SSD drive.
I normaly use the Macrium software solution. I hope it is also suitable for the this action. Hopefully this software will recognize the original BS3200 harddisk.
I am very pleased and thankful with all your tips, information. If you have any questions about my plan, please do not hesitate to ask.
I thank you all for your kind help.🙏
Kind regards, vriendelijke groet, herzliche Grüsse,
Marcel
(Eindhoven-Netherlands)
Page 1 of 1 (1 items) | RSS
