Same thing happens to my installation, both in Vista and Windows7. Boring...
Brgds Ingvar
Earlier; BV 10-46, 2*BL3, BM5/BS5, BS9000, BL8000, BV7-32, MX7000, Beoport, Beocord 8000, MX4002, BL2000, Beocom1, Beotalk1200
You and Jan appear to be having problems running the Configuration Tool version 6.0 which needs to be identified, so I would ask you please to provide the following information:-
To review the "Event Log" on Windows 7 Click START then CONTROL PANEL then SYSTEM AND SECURITY then under the heading at the bottom marked "Administrative Tools" click VIEW EVENT LOGS as shown below
Regards Keith....
1. 2 GB at least
2. No exept of the normal Vista system
3. No, but at some earlier point there was some sort of error message in the start of the program, but that doesn´t appear any more.
4. Yes, here is the error report, a little in swedish.
Beskrivning Stopped working Problemsignatur Händelsenamn: CLR20r3 Problemsignatur 01: beo5ct.exe Problemsignatur 02: 1.0.4505.18550 Problemsignatur 03: 4fa0edcc Problemsignatur 04: Common Problemsignatur 05: 1.0.4505.18489 Problemsignatur 06: 4fa0ed52 Problemsignatur 07: 11e Problemsignatur 08: fd Problemsignatur 09: System.IO.IOException OS-version: 6.0.6002.2.2.0.768.3 5. I have Vista with all latest updates. I´m really happy for all help I can get. Brgds from Ingvar
Beskrivning
Stopped working
Problemsignatur
Brgds from Ingvar
Thank you for your update Jan.
I would say that the issue was resolved with the USB driver as this is the most common area where problems exist.
The error shown in the previous posting from the Windows error log shows an "Unhandled Exception" meaning that an error occured in the application, but the configuration Tool did not have any error handling for that particular error condition and so was trapped by the operating system.
So, we really had two problems the error itself which may be USB driver related and a software problem in the configuration tool for not catching the error condition and reporting it to the user.
I also fixed a little with the USB-driver and suddenly everthing works. I really appreciate your efforts to help me! Thanks and best regards from Ingvar in Sweden
