Hi, does someone knows what settings are changed on the Beomaster 5 when Music server is activated on the Beosound 5? I have only the BM5 and would like to be able to enable the music server. A lot of settings seems to be stored in the registry. Under HKEY_CURRENT_USER/Software/Bang & Olufsen there are different folders. One of the folders are called Beosound5 and below that you will find folders called MOTS and MediaAgent among others. Under MediaAgent there are a folder called DLNA. Here I have a registry value IncludeLocal with value zero. Is there that knows how the values in this folder looks if you have activated the MediaServer on the BS5? Have you noticed anything else that changes?
