I'm looking at a Beocenter 9000 and most of the unit is dead. St. by relay RL1 on PCB63 is turning ON and supplies are present but there are no light in LEDs and touch pads are not responsing. The three electrolytical capacitors on CPU PCB40 is changes due to low value but that did not solve is issue.
IC1, IC4 and IC6 is not in Reset.
Capstan in tape section are running. The unit is not reacting on remote control commands and it is not possible to active Test mode. I could assume something is wrong from CPU side, but what?
/Pindsen
Backup battery dead?
No, it measures 3.2VDC.
