BEOGRAM 5500 tone arm and detector slidding problem
This post has 0 Replies | 0 Followers
Ignacio
Barcelona
Posts 39
Ignacio Posted: Sat, Jul 10 2021 12:26 PM
Hello
I'm trying to fix a Beogram 5500 tt, but I can't. The detector arm is not moving to the left even moving manually the arm. Everything looks fine and the wire is Ok, also repaired.
When play is pressed the cart moves to the starting point and the white back lever permits stylus to go down, but the slide is not moving.
If I disengage the slide following SM instructions l can manually move the slide ans the mechanism looks fine.
It looks to me that 1634 wheel is not touching properlly the axe moved by the motor, because the cooper metal piece is not pushing enough or maybe one of the tooth wheels is out of place.
When the platter is spinning after play and I want to move the slide with the arrow direction buttons, if I push left, the slide moves a bit to the right....?
Any ideas to help me?
Thank you in advance
Page 1 of 1 (1 items) | RSS
