Beocenter 9500 CD problem (not the capacitor story)
This post has 20 Replies | 2 Followers
69er
Posts 110
69er Posted: Tue, Jul 13 2021 9:46 AM
i am currently working on a Beocenter 9500 and i am stuck at the CD part.
After (and before) replacing the most common capacitors the CD won´t run.
And it seems to be something different, as the standard faulty behaviour is that the motor spins, the lens can´t focus and after two turns it stops turning.
In this case its different - the motor does not start at all.
Is there any experience or help available how to proceed? I have a spare Beocenter 9000, but unfortunately the CD mechanism is totally different, so i can´t swap.
Bes regards
69er
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Tue, Jul 13 2021 10:37 AM
69er:
Which type (brand etc.) of capacitor did you fit for C2103 (the blue Philips axial)?
69er
Posts 110
69er replied on Tue, Jul 13 2021 11:33 AM
Nothing special.
during my last repairs ,I had several 9500 before, I did not see any difference in the behavior dependent on the type or manufacturer.
but as said, the motor won’t even start, so I think this capacitor wasn’t even the issue.
how could I check if the motor itself is the problem?
besf regards and thank you for your help
69er
Dillen
Posts 13,191
Dillen replied on Tue, Jul 13 2021 12:51 PM
We've seen this situation countless times.
You can read more here:
Troubleshooting Philips CDM4/24 Laser in BeoCenter 9000 - (beoworld.org)
and several other threads (search for C2103).
I would fit the correct type of capacitor before anything else.
A kit is available from Beoparts-shop.
69er
Posts 110
69er replied on Tue, Jul 13 2021 1:38 PM
Hi Martin,
ok - i´ll try the original Philips 33yf.
Crossed fingers :-)
Best regards
69er
Dillen
Posts 13,191
Dillen replied on Tue, Jul 13 2021 2:52 PM
69er:
Hi Martin,
Crossed fingers :-)
Best regards
69er
Not THE original.
An unused one!
69er
Posts 110
69er replied on Tue, Jul 13 2021 4:26 PM
Of course 😉
the old one is already in the trash can.
i just ordered a bunch of original philips caps
best regards
69er
69er
Posts 110
69er replied on Fri, Jul 16 2021 6:01 AM
So, I exchanged the capacitor with a Philips (new).
no change.
but what I recognized now, is that the cd is not a cdm4/33.
instead it’s a cdm4/57 - don’t know why.
if I am not wrong this is not the right one, correct?
could it just be the wrong CD player which somebody has installed?
best regards
69er
Dillen
Posts 13,191
Dillen replied on Fri, Jul 16 2021 6:25 AM
Any chance of a photo of your servo board as it is now?
69er
Posts 110
69er replied on Fri, Jul 16 2021 10:03 AM
Hope this helps
Best regards
69er
Dillen
Posts 13,191
Dillen replied on Fri, Jul 16 2021 11:44 AM
Burned resistor in the motor drive circuit.
Perhaps because of a shorted driver transistor.
I would replace both transistors (note their type and don't trust the manual, most have a serious typo there) and both resistors (10 Ohm fusible if I remember correctly).
69er
Posts 110
69er replied on Fri, Jul 16 2021 12:55 PM
Wooooow!
you can see that from the picture? Impressive.
as I am a total non electronic guy - just can solder a little bit - would you mind showing me the parts?
best regards
69er
Dillen
Posts 13,191
Dillen replied on Fri, Jul 16 2021 1:33 PM
Actually not that difficult to spot.
Between transistors 6124 and 6125 and the black connector.
New part here.
69er
Posts 110
69er replied on Fri, Jul 16 2021 1:47 PM
Hi Martin,
thanks a lot !!!!
Now i am really curious, if i can make this thing run again. Will take a look at the transistors and then order the new parts.
Great forum - great experts Thumbs Up
69er
Posts 110
69er replied on Sat, Jul 24 2021 3:47 PM
So,
i exchanged the 10ohm resistor, 338 and 328 Transistors.
behaviour now: the cd spins immediately after switching on power.
but: the direction is wrong and the speed is teslalike - much to fast.
i saw some post regarding pcb31 and a transistor there (6314), but my board doesn’t have that.
martin: I need your help again
best regards
69er
Dillen
Posts 13,191
Dillen replied on Sat, Jul 24 2021 5:36 PM
Which types of transistors did you fit for the two positions respectively?
Photos front and back?
69er
Posts 110
69er replied on Sun, Jul 25 2021 4:08 PM
Hi Martin,
i installed
BC338-25 Transistor NPN 25V 0,5A TO92 from CDIL
and
BC328-25 Transistor PNP 25V 0,5A TO92 from CDIL.
But i changed only one of the fusible resistors. The burned one - need to check the other (besides him?)
Here is a picture of the other pcb - maybe here is something wrong?
Best regards
69er
Dillen
Posts 13,191
Dillen replied on Sun, Jul 25 2021 7:00 PM
It's possible that there is a problem on the decoder board, but it's nothing I can see in the photo.
I have noted transistor 6314 (BC818-16 SMD) failing a few times.
You could check the +/- 9,5V supply voltages.
69er
Posts 110
69er replied on Sun, Jul 25 2021 8:11 PM
Hi Martin,
yes i saw in several posts the 6314 as possible source got this behavior, but I can’t find it.
could you help me by marking the location?
best regards
69er
Dillen
Posts 13,191
Dillen replied on Sun, Jul 25 2021 9:29 PM
I don't recall its exact position, and there are slightly different board versions but, being an SMD, it's found on the underside of the decoder (Module 31) board.
69er
Posts 110
69er replied on Sat, Jul 31 2021 11:19 PM
Hi Martin,
it was easier then expected. There is only one smd transistor on the backside fortunately.
otherwise I would not have known which one to exchange.
Result: the CD player is playing again.
THANK YOU Martin !!!!
It makes really fun repairing these old icons. But without the help of such experienced professionals like you it would be close to impossible (as said, I am not an electrician),
all the best (wherever you are)
stay healthy
69er
Page 1 of 1 (21 items) | RSS
