Beovision 9 sound problem
This post has 8 Replies | 0 Followers
mbdj
Posts 74
mbdj Posted: Sun, Jul 18 2021 12:25 AM
The centre channel has stopped working on my Beovision 9 my front beolab 5’s work fine and my beolab 4000 rear speakers also work I’ve not changed any settings that I know off any help would be appreciated.
The Beonic Man
Bristol
Posts 812
I was a BV9 owner along with BL9s but never came across this issue. The only thing I can think to suggest is a total system reset, so unplug all equipment and leave disconnected from the main for about an hour or so or even overnight. More than you need too, but that’s what I would probably try. You could double check the sound settings through the menu I guess although if you haven’t changed anything to date then I can’t see what more you could do. I am sure others with much more experience will chip in but for my part that’s all I can think I’d do in the same situation before contacting B&O for help. Best of luck.
Simon.
B&O products are V1-32, BS2, H95, E8 and an Essence remote.
11-46 now replaced with Sony A90J 65”, Sony HT-A9, Sony UBP-X800M2 and Sony SRS-NS7.
expoman
Posts 182
Silver Member
expoman replied on Sun, Jul 18 2021 6:15 AM
Were you playing a video source at a very high volume by chance?  Unplug the TV and wait 45 seconds and then plug it back in.  Does the center channel sound play now?
mbdj
Posts 74
mbdj replied on Sun, Jul 18 2021 9:53 AM
Hi Simon ,
I’ve turned it off overnight but it’s still the same I’ve checked all the settings and they seem the same when I check speaker roles in the menu all the speakers are highlighted but the centre 1 speaker looks faded.
mbdj
Posts 74
mbdj replied on Sun, Jul 18 2021 9:55 AM
I don’t have the volume any higher than 40 to 45 for tv and higher for music I’ve tried unplugging it and plugging it back in but it makes no difference
beoandy
sissi not kangaroo
Posts 329
beoandy replied on Sun, Jul 18 2021 11:41 AM
unplug the bv9 for 3 to 5 minutes. (the entire bv9 not just the bs3!) did you make changes to the bs3? check whether the center is plugged into the bs3 with powerlink.
BS Ouverture, BS 9000, AV 9000, Avant 32 DVD, BV9, BV6-22, BS 5, BS 4500, BS 7000, BC 9500, Beo6, BL Penta, F1000, BLGW, etc....
mbdj
Posts 74
mbdj replied on Sun, Jul 18 2021 12:52 PM
I’ve tried unplugging both and it’s made no difference I’ve moved the centre speaker cable to one the works and I have no output so I think it must be the centre speaker or power link cable that connects it that’s at fault is it easy to access the front speaker or the power link cable?
expoman
Posts 182
Silver Member
expoman replied on Sun, Jul 18 2021 4:00 PM
it sounds like a failure in the ice power arm for the center channel. A friend has had a similar situation but his returns after unplugging the TV from the wall.
mbdj
Posts 74
mbdj replied on Sun, Jul 18 2021 5:21 PM
Did he replace the part ? Is it part of the speaker or is it a separate amplifier?
Page 1 of 1 (9 items) | RSS
