Hello there,
I am so happy that I finally got my hands on one of my dream Bang and Olufsen pieces of kit. The Beocenter 8000 *dramatic sound effect noises*. Now one thing to solve. I bought it from the UK and I live in the US.
I was thinking of buying something like this to convert the power: https://www.amazon.com/Simran-AC-500-Voltage-Converter-Transformer/dp/B004MPR3XG/ref=sr_1_3?dchild=1&keywords=120v%2Bto%2B240v%2Bstep%2Bup%2Btransformer%2B300w&qid=1629078337&sr=8-3&th=1
However, before buying it, I wanted to see if anyone knows of a way that you can convert the unit (without buying a new power supply.)
-Noah M.
RL 60.2, Beogram 5500, Beomaster 5500, Master Control Pannel 5500, Audio Terminal Remote, H9i, Beovox s45.2, Beosystem 2500 , Beogram 1602, Beolink 1000 remote, Beosound 2000, Beoremote 4.
Looking for: Beocenter 8000
Most of these Beocenters can be wired internally. Some even have a rotating switch.Did you look inside?Did you check the servicemanual?
Hey there Dillen. I haven't looked inside yet, however I haven't seen any mention in the manual/service manual.
