Level vs. Beosound 1
This post has 43 Replies | 1 Follower
Hiort
Sweden
Posts 2,895
Hiort replied on Mon, Oct 18 2021 8:49 PM
Curly:
B&O customer support emailed me today requesting screenshots of my menus. Apparently, ALARM is supposed to be immediately visible in the menu once you select LEVEL from your product list.
This is not the case for me.
Can Level owners verify their software version? I have auto-updates on and my Level software is 1.6.25. My B&O iPhone app is also the latest available 3.18.2.39953.
I just wonder if maybe I haven't received the latest software update for some reason. Thank you!
Currently: BeoLab 17, BeoLab 18, BeoSound Core, Beosound Level, Beosound A1 2nd Gen, BeoPlay S8 Connection Hub, Essence Remote
Previously: BeoSound 1 non-GVA
That is the latest app sw.
Same for my Emerge. No alarm.
Think the developers are not in synch with supportteam.
Csaba
Oslo, Norway
Posts 216
Csaba replied on Mon, Oct 18 2021 10:34 PM
Curly:
Have you tried re-adding your Level to the B&O app since you updated the app to the latest version that includes the alarm?
Curly
FL, USA
Posts 366
Curly replied on Sun, Oct 24 2021 8:15 PM
B&O confirmed the software update included notes about the alarm when it shouldn’t have. The feature isn’t ready yet. They said it will be available likely in one month from now.
Currently: BeoLab 17, BeoLab 18, BeoSound Core, Beosound Level, Beosound A1 2nd Gen, BeoPlay S8 Connection Hub, Halo, Essence Remote
Curly
FL, USA
Posts 366
Curly replied on Mon, Oct 25 2021 2:13 PM
Oh, and they suggested that when it does get released, it will be directly available from the product menu. Tap the Level in the B&O app and ALARM should be pretty much right there--I'm guessing where Product Settings is right now... or maybe within that menu. So it should be pretty easy, as it should be.
What a pretty alarm clock. :)
Page 2 of 2 (44 items) < Previous 1 2 | RSS
DigiCert Secured Site Seal
