Dear BEO Forum,
I hooked up my Beolabs 1 to my brand new core after getting rid of my horrible (sorry but true) Beosound moment. One speaker is a bit nearer then the other so i needed to adjust my balance..............
HELP, i cant find it ? Cant tell me its not there ?? Manual is not showing any settings explanation at all, App is just showing High and Low settings.............
Greetings and hope you can help me
p.s. still love B&O just not the moment
I was about to go for a core last spring but the lack of balance adjustment was one of the reasons i didn't. The dealer told me it was in the "wishlist" for future software updates but not with highest priority.
Welcome to the forum
Kind regards
Goran
Thanks Goran !
Audio playback is superb, but lack of balance is unthinkable. Incredible this is lacking. I cant even find the release notes for the core to
see what they updated yet. My dealer says they only have 20 programmers working there but not on the core at the moment
Jan
Can be found under "Sound Controls."
Beofile7:Can be found under "Sound Controls."
I am also thinking about replacing my Moment with the Core.
Question: apart from the balance settings is there also a loudness setting?
Essential for me for low volume playing.
thx. Peter
PeterBOBP:Question: apart from the balance settings is there also a loudness setting?
thx!
