Automating a BeoSound 2500 with Amazon Alexa
Noah
San Francisco
Posts 71
Noah Posted: Tue, Aug 24 2021 4:33 AM
Hello All,
Recently I decided to get an Amazon Alexa and wanted to make it control my B&O Beosound 2500. I did a quick search and I found the BroadLink RM3 Mini. I got it and when I tried to program the remote in, the app didn't recognize that there was any ir signal being received. I tried with a remote from my tv and it detected in the app perfectly. Do any of you know how to link an Alexa to a Beosound 2500?
My guess is that the Audio Terminal remote I use is on a different IR wavelength than what is currently being used today.
Thanks,
Noah
-Noah M.
RL 60.2, Beogram 5500, Beomaster 5500, Master Control Pannel 5500, Audio Terminal Remote, H9i, Beovox s45.2, Beosystem 2500 , Beogram 1602, Beolink 1000 remote, Beosound 2000, Beoremote 4.
Looking for: Beocenter 8000
RaMaBo
near Munich
Posts 626
RaMaBo replied on Tue, Aug 24 2021 11:38 AM
the IR wavelength is not the problem in our case but the IR carrier frequency.
The most IR remotes use a crrier freuency of 36 or 38 KHz, some use 56 KHz. B&O used 455 KHz as the carrier frequency which far hgher than the usual used. The Broadlink receiver is most probably only useful for the 36 -38 KHz range, so no luck this way.
Ralph-Marcus
Noah
San Francisco
Posts 71
Noah replied on Tue, Aug 24 2021 7:36 PM
Hello. Thanks for your reply. Would there me a way I could mod my Broadlink by putting in a different IR emitter/receiver?
-Noah
-Noah M.
trackbeo
Posts 644
trackbeo replied on Tue, Aug 24 2021 8:59 PM
I hope someone gives you the answer you are looking for, but two possibilities popped into my head:
(1) My Logitech Harmony Home Hub, despite not being able to accept/input B&O codes, is able to output them, when you choose, say, a Beovision from its library of pre-programmed devices and drive the TV using the app's virtual buttons.  Maybe, if you're lucky, a similar IR output chip/strategy was chosen by BroadLink and their library has been programmed up for you?  (If you're already this far in the setup, probably not, but it's worth at least asking the question: do they have any pre-programmed B&O gear?)  For that matter, you could just switch from BroadLink to the Harmony, but that requires finding and buying a discontinued product and reading support threads associating Logitech remotes with Alexa skills.
(2) www.lintronic.dk makes converters so your B&O remote can control non-B&O IR products  -- and vice versa, which is what you want.  You would tell the BroadLink RM that you are using a Sony (or whatever) receiver & CD and tell the Lintronic TT to accept Sony codes as input and generate B&O codes as output.  Given their respective prices, it's sort of putting the cart before the horse,,. but if your hacking efforts don't pay off, you have a backup.  (For that matter, Lintronic has a support document that describes how they use Alexa directly, but it seems to require receiving e-mails or SMS as the control stream?)
Noah
San Francisco
Posts 71
Noah replied on Wed, Aug 25 2021 2:51 AM
Hello. I may go with the harmony hub as I only need it to output to my system. Could you send me a link to the product on eBay. Im looking for one under 40$.
Thanks,
Noah
-Noah M.
Noah
San Francisco
Posts 71
Noah replied on Wed, Aug 25 2021 2:55 AM
There isn made for broad link. Would this hub work?
https://www.ebay.com/itm/124860644985?hash=item1d12463e79%3Ag%3AxbYAAOSwchBhH
g1Y&LH_BIN=1
-Noah M.
trackbeo
Posts 644
trackbeo replied on Wed, Aug 25 2021 8:27 AM
To ensure you aren't "taken for a ride" by a seller substituting the older, almost-identical "Harmony Link" (which Logitech completely replaced and sent out new models *for free* to existing owners!) from their waste bin, you want Harmony Hub model # 915-000238.  (The link you posted had some random model #, but I saw a listing for 915-000238 for less than $40, brand-new.)
Page 1 of 1 (7 items) | RSS
DigiCert Secured Site Seal
