Beomaster 1900 i need help with its repair
Camiloastu
Posts 3
Camiloastu Posted: Sat, Aug 28 2021 5:39 AM
I need help with my beomaster 1900, when I turn on only the function selector blinks and turns off, the volume remains on but the buttons do not work, can someone guide me in the repair ??? a big greeting !!!
I leave a video with the problem
https://drive.google.com/file/d/1-On-UppfStLIfKOyLJsQ6E51BObYdfLs/view?usp=sharing
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Sat, Aug 28 2021 7:53 AM
Unstability in power supply.
Bad capacitors, bad rectifier, bad lamps, faulty selector IC.
Or any combination.
All very common for a Beomaster that hasn't been restored yet.
Parts here.
Camiloastu
Posts 3
Hello Martin, thank you very much for your help, I will start with the IC selectors,
the volume toch bonnets do not work from the panel. but if they respond when pressing the pin on the board. do you have any idea of ​​the problem?
Greetings.
Dillen
Posts 13,191
Dillen replied on Mon, Aug 30 2021 1:30 PM
Sounds like the front panel wasn't fitted correctly.
The small bronze forks under the touchpads need to grip their respective pins on the boards.
Camiloastu
Posts 3
Hello Martin
Thank you again, I have reviewed the installation of the front panel and the small bronze forks hold their respective pins.
I have tried touching the pins with a non-rubberized screwdriver and the system works, when testing the pins with a rubberized screwdriver the pins do not work.
will I need some land?
a big greeting
Page 1 of 1 (5 items) | RSS
