It sounds like it's set to work with a Beo4 Navi controller -- that is, a newer Beo4 that has the joystick in the middle or a BeoRemote One. You have a non-navi Beo4. If I remember correctly, you need to enter the number of the line in the menu to get to the menu setting where you can change the IR controller over to non-navi.
