Beosound 9000 Tacho wheel
mr_anders_son
sweden
Posts 1,710
mr_anders_son Posted: Sat, Aug 28 2021 4:06 PM
Someone knows where the taco wheel is located on the Beosound 9000?
On the sledge or?
BeoVision Haermony 65"...BeoLab 28 Anthracite....BeoLab 17 as REAR....BV10-32....BC6-26....Beosound 9000....Beosound 1 New York edt....Beogram 4002....Beoplay Emerge....Beoplay M5....Beoplay M3....Beoremote Halo....BeoRemote One BT....Beo6....Beo4....Beo4 Cinema....BeoLink 7000....Serene....H95 Black LTD....H9i Rimowa....6 x H6....Form 1....U70...
matador43
Posts 1,373
matador43 replied on Sat, Aug 28 2021 6:13 PM
Under the left upper part, the metal plate that does not open. You release it, take off the upper plastic casing and you acces the tacho wheel next to the sledge motor. Can't find the thread right now but I'm quite sure you can find pictures on the forum since We've talked about fitting the wires back arund the pulley just next to the tachowheel.
mr_anders_son
sweden
Posts 1,710
Thanx!
Solved!!
Page 1 of 1 (3 items) | RSS
