Two beolab 2 with beovision 10-40
oim1212
Posts 35
oim1212 Posted: Sat, Aug 28 2021 6:54 PM
I have recently got my hands on a BEOVISON 10-40 and I have some extra beolab speakers and I was thinking of making a movie setup. The question is if I can use 2 beolab2s with the surround setup and do you think it will make a difference? And if it does how should I wire it, powerlink from the first beolab 2 to the second? Thanks!
Millemissen
Flensborg, Denmark
Posts 14,680
Sure, you can do that.
However it depends very much on the room and the placement of the subs.
Since the BV10 does not allow for any advanced bad management, you will have to daisy chain the 2 and finetune on the subs.
You will need to experiment a bit with placement and settings.
My advice - don’t let the subs be to dominant, the must blend in with the overall sound of the (tv) speakers.
Which other speakers are you connecting?
In order to have ‘a surround setup’, you need front and surround speakers with the BV10.
beojeff
USA
Posts 2,012
beojeff replied on Sun, Aug 29 2021 1:32 AM
oim1212:
I've used two Beolab 2 speakers and it does give a more balanced result where you do not sense the location of the subwoofer. You can use a powerlink Y-splitter.
oim1212
Posts 35
oim1212 replied on Sun, Aug 29 2021 3:59 PM
Okey thanks I was thinking of having beolab 8000 as fronts and beolab 3s as rear. Could I just plug in o the second sub in to the first one if the first one is connected to the “sub” on the BEOVISON 10?
Millemissen
Flensborg, Denmark
Posts 14,680
I’d (as beojeff writes) use a powerlink Y-splitter.
The out connections on the sub itself are meant for connecting a set of ‘normal’ Beolabs e.g. in a stereo setup.
Use the splitter, when the setup is a dedicated 5.1 setup with the BL2 connected to the subwoofer output of the BV10.
Page 1 of 1 (5 items) | RSS
