Beovision 11 - Sound Problems!
chris621x
Posts 2
chris621x Posted: Mon, Aug 30 2021 11:37 AM
Recently bought a Mk4 Beovision 11-46 to replace my very old Beovision 3.   The picture is good, the design really nice, but the sound (from the internal speakers) sounds very 'thin' compared with the old Beo3.
Speech is particularly weak, and during a movie it is often really hard to understand what is being said unless the volume is really loud.  The speech is subdued and hard to make out.
I've played with every sound setting, including resetting to default in desperation and starting again. My hearing is fine (I'm subjected to an occupational hearing test very year) and my partner (who has hearing like a bat!) says she can't hear the speech clearly either.
The Speech Enhance function just seems to make the speech very 'tinny' and even harder to hear.  The various adjustment modes (bass. treble etc) don't seem to do a great deal.
Grateful for any help/advice since watching a movie is near impossible (without subtitles!).
Millemissen
Flensborg, Denmark
Posts 14,680
Welcome to the forum.
Sorry to say it…..there must be something wrong with (the speakers of) your BV11.
What you describe is not what other BV11 owners tell and definitely not how it is intended to be.
Back in the days when the BV11 was launched member KMA made a long thread about his then new BV11:
https://archivedforum2.beoworld.org/forums/t/3372.aspx?PageIndex=1
Maybe reading that could give you some hints about what to do.
Where did you buy the tv - if it really is as you write, I’d return it.
Hiort
Sweden
Posts 2,895
Hiort replied on Mon, Aug 30 2021 6:16 PM
Definitely something wrong.
BV11 has great sound and voices should be crystal clear.
Could be the ICEpower amps that has problems.
B&O engineer can test if they are needed to replace.
I had to replace one some time ago, but the diagnosis was different. More a crackling noice from one speaker.
beosound
Posts 91
beosound replied on Mon, Aug 30 2021 7:22 PM
I don't think so. If the pre-owner had a 5.1. setup, the speakers will act as center speaker! Please look at the role of the speakers!
Millemissen
Flensborg, Denmark
Posts 14,680
beosound:
However, it does not seem so.
Chris…. wrote, that he ‘played with every sound setting, including resetting to default in desperation and starting again.’
And even if the built-in speakers were ‘set to’ act like a center channel, they should not sound as described.
Let’s wait and see if he reacts to our posts.
chris621x
Posts 2
chris621x replied on Mon, Aug 30 2021 8:07 PM
Thank you everyone for all your responses.   I've reset everything to default (to try to get around any previous programming) and made sure the software was up to date (it said it didn't need a software update when I 'asked' it).   It sounds like there might be something wrong, so will see if I can get someone to come and look at it.   By the looks of the long tread on BV11, the sound should be really good, and it generally is apart from sounding 'thin' and a bit feeble in the mid-range.  So sometimes you need to really strain to hear speech.
I thought at first it might be just an effect of the thin 'case' of the BV11 compared with the 'cavern' which surrounded my old BV3.
In desperation, I was considering getting some second hand Beolab 6000s to try to make sound of speech 'better'.  Sounds like more investigation required first.  Do B&O technicians have something they can plug into the TV to test it?
Hiort
Sweden
Posts 2,895
Hiort replied on Tue, Aug 31 2021 9:56 AM
chris621x:
An experienced B&O engineer will for sure hear if there is a problem. I do not think there are so many different things that can be wrong. My bet is that some amplifier needs replacement.
Page 1 of 1 (7 items) | RSS
DigiCert Secured Site Seal
