Does anyone know where I can obtain a new glass door for a B&O Century?
From B&O?
Too long to list....
Hello
The glass door for the BeoSound Century is still available from your local Bang & Olufsen dealer. The part number is 3162063.
Note that this is the later verison and is suitable for models from serial number 11081975 on onwards.
If your serial number is lower than this, the glass door has a different part number but this version is no longer available.
Regards
Opman
ferrari458spider: Does anyone know where I can obtain a new glass door for a B&O Century?
If you still have the (broken) door with the bracket on it then go to a glass store and let them make a new one.
Remove the bracket, paint a black stripe and use epoxy to glue on the new door. As simple as that...
Brengen & Ophalen
