Beovision 6-26 lost pin - a write off?
LarsJensen
Posts 35
LarsJensen Posted: Sat, Sep 11 2021 10:21 AM
I bought a use Beovision 6-26 some years back and got the pin from the seller on a text.
Have been going through my old iPhones with no luck.
Is it a write off or are there any way of getting it reset?
Seems a pity just to write off this beauty but it will be a lot cheaper to buy a used replacement than getting it by a B&O service.
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Sat, Sep 11 2021 12:09 PM
LarsJensen:
Just phone your dealer. He can provide you with a master-pin to unlock the BV6.
I had a simular situation when I bought a second hand one (cheap).
LarsJensen
Posts 35
Carolpa:
Thanks, will do that.
Page 1 of 1 (3 items) | RSS
DigiCert Secured Site Seal
