Troubleshooting a Masterlink Network.
SharpEars
Posts 5
SharpEars Posted: Sun, Sep 12 2021 5:35 AM
My ML network at home is as follows:
Beosound 9000 is the hub of the network and is located in the centre of the home with no speakers attached to it.
Great Room is a pair of Beolab1’s with a Beolink Eye on the wall and an active box in the wall cavity.
Kitchen has a Beolab 2000.
Study has a Beolab 3500
Ensuite has a Beolink Passive amplifier connected to some Nakamichi speakers in the ceiling and a Beolink Eye on the wall.
The system was installed around 2003 and has worked faultlessly until a kitchen renovation required changing the position of the BL2000. A ML cable had to be cut and rejoined.
The symptoms of the issue are as follows:
I am unable to switch on the 9000 using the control panel button or remote.  The unit shows a red standby light but does not light up as expected until I repower the unit.
Remoting on or using the Beolink Eye to switch on other components has no effect pre or post repowering the 9000.
About 5 minutes after repowering the 9000 and selecting radio, voila - the various speakers come to life and now the remote works with every element. Now the system works as one would expect.
Has anyone else experienced this and resolved it?
Thanks in advance.
Page 1 of 1 (1 items) | RSS
