BeoCom 6000, 2 and 5 not ringing anymore when receiving outside calls
Griebel
Posts 416
Griebel Posted: Sat, Sep 18 2021 3:30 PM
I noticed today that all my 4 BeoCom phones not longer ring when I receive outside calls. The BeoCom 6000 and 2 display the number or name of the incoming caller, while BeoCom 5 does not display anything.
The phones still ring when I call them via the internal phone network, and outside calls work just fine. Ringing is correctly setup on ON on all the phones.
Has anyone ever had a similar experience, and if yes, how can I solve the issue? Just wanted to make sure it's not a problem with the phones before contacting the hotline.
Thanks.
Griebel
Posts 416
Griebel replied on Sat, Sep 18 2021 4:03 PM
Problem solved. Did a reset of my internet box.
Ryan Smyth
Northern Ireland
Posts 3
Hi there,
Just out of curiosity, are you in the United Kingdom? If so, are you using BT's digital voice service, or something similar with another provider?
I am having this issue at the moment. I can make outgoing calls, but I cannot recieve incoming calls. It rings for a moment, then cuts off. If you have any advice, please share it.
Kind Regards
Ryan
Griebel
Posts 416
Griebel replied on Sat, Dec 4 2021 11:23 AM
No I’m not UK. Have you restarted your internet box?
Ryan Smyth
Northern Ireland
Posts 3
Will give it a go. Thanks
Page 1 of 1 (5 items) | RSS
DigiCert Secured Site Seal
