BeoRemote application
symmes
Posts 247
symmes Posted: Fri, Feb 22 2013 2:54 PM
I have it for iPad and it works nicely.
Would anyone know of an EASY workaround to download the BeoRemote app to a Kindle Fire HD?  A couple of the BeoApps are available via one of the download sites, but BeoRemote is only available on Google Play, and Kindle can't access it without great hassle.  It's Android, but Amazon inserted some nasty protection from the greater community.
Thanks.
BeoHut
Posts 482
BeoHut replied on Fri, Feb 22 2013 5:08 PM
Perhaps the next is possible.
Look for an App-storesite where the app is available. For example Germany or The Netherlands.
Then make a new and free app-id and download the app.
Not sure if this would work, but give it a try.
Probably on Google Play-sites you can find the BeoRemote app.
symmes
Posts 247
symmes replied on Fri, Feb 22 2013 11:42 PM
Thanks for your insight.  Kindle Fire HD won't access the Google Play site, so I will go hunting on Euro sites tomorrow.
r
Page 1 of 1 (3 items) | RSS
