So im wondering. I have a beogram 3000 coming soon (been chasing it for years) but i really love the beogram 1202 plate. Are they interchangeable? Could the 1202 metal matt fit on the 3000? are the 45 puck holes the same size?would the 1202 platter slot on the same way? has anyone tried this before?
If anyone would let me know i would really appreciate some feedback.
Also i heard that the motor on the 3000 is better than the 1202 and the 1203 is that true?
Cheers.
BG1202 platter should be fine on BG3000. The hole cutouts are the same so should br fine. As far as the motor goes … I think they should be the same.
