I connect Amiga to my Beo 4002 and the picture rolls slowly upwards. Can I adjust the sync of the Beo if I open it up? Is it possible? I have gone through the service settings and none let me adjust the sync or hod sync.
As far as I understand, none of the Unity chassis Beovisions have any provisions for adjusting the sync frequencies. You would need to change some components and that would put a lot of the circuitry out of spec. I suppose it will be far easier to find a way to slightly tweak the frequencies in the Amiga display settings (but don't ask me, I was a Sinclair guy...).
--mika
