BeoCord V3000 VHS
Eervi
Posts 4
Eervi Posted: Sat, Oct 16 2021 4:06 PM
Hej!
I have, just arrived via post BeoCord V3000 VHS
I´m lost :-(
My VHS is inside ... well I push it there .. That can I do with a  screwdriver.
But how i use it? It´s only show some light PROG and red clock is blinking.
I have Beolink 1000 and terminal 3000
So I need Help.
-lm-
lawrencejmcook
Posts 742
You need to connect it to a Beovision with a fully wired SCART cable. Your remote control will address the television, and the television will relay the commands to the V3000 via the SCART cable.
Eervi
Posts 4
Eervi replied on Sat, Oct 16 2021 6:09 PM
Hej!
- Okey, great :-)
- So wich Beovison is good for that and remotecontrol.
Still I´m B&O. fan...
-lm-
Eervi
Posts 4
Eervi replied on Sat, Oct 16 2021 6:15 PM
B&O BeoVision 6 ? is that okey ?
lawrencejmcook
Posts 742
I would imagine almost any from LX6000, MX6000, BV5, BV6, BV7, BV8, BV9.
Less sure about BV10. It has SCART, but I don’t know if it has “AV Link”. Check the product specs on Beoworld in the Products section.
The later TVs don’t have SCART sockets.
Eervi
Posts 4
Eervi replied on Sat, Oct 16 2021 9:00 PM
Hej!
thank you,  me  :-)
-lm-
Page 1 of 1 (6 items) | RSS
