Hi
When I put a CD the laser does the focus movement but the CD does not spin.
When I try without CD the laser does the focus movement and the motor spins twice.
It started to play a CD once and I stopped it after one minute, but never could start it again.
After putting it in the service mode I get error 2 : focus error
I can see in the dark the laser turning on.
So it looks like there is effectively a focus problem and that the TOC is not getting read.
The unit is a VAM1255/21, the laser unit has been changed 5 years ago by a B&O dealer.
Anyone had this problem ??? where should I start ??? would it be one of those caps problem ???
