Only right channel sound from beogram 9500
This post has 5 Replies | 0 Followers
IBAndreas
Posts 5
IBAndreas Posted: Thu, Dec 16 2021 3:39 PM
Hello,
I have recently put together my dream system:
Beosystem 9500 + beogram 9500 + MMC4
They are currently connected to a pair of beolab 6000
My problem is that, while sound plays fine from the CD and the radio in the left and right channel, when I play an LP on the beogram 9500 - I only get sound from the right channel.
Your help would be immensely appreciated.
I have already tried changing cables, dipswitches on speakers, taking out and putting back the mmc4 cartridge, double checked connections etc.
All the best and happy holidays!
Andreas
sonavor
Texas, United States
Posts 3,732
sonavor replied on Thu, Dec 16 2021 5:09 PM
How old is the MMC-4 cartridge?
Do you have another MMC type cartridge you can try?
It is fairly common for the MMC cartridges to lose a channel with age.  The problem can be repaired by a cartridge restoration expert (FJS Tonabnehmer Service or Soundsmith).
-sonavor
IBAndreas
Posts 5
IBAndreas replied on Thu, Dec 16 2021 10:44 PM
Well I did buy the needle refurbished from a “reputable” dealer.
but inguess the best to do is try to get ahold if an mmc cartridge in Stockholm to try to verify it. Thanks for the advice!!
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Fri, Dec 17 2021 6:53 AM
If the problem is the same with a replacement cartridge, check inside the Beograms DIN plug for a broken lead.
Beofile7
Posts 150
Beofile7 replied on Fri, Dec 17 2021 10:08 AM
I had the same issue. It is a defective cartridge. I have an MMC4 just rebuilt from FJS (unused) available...in Stockholm!
Dillen
Posts 13,191
Dillen replied on Fri, Dec 17 2021 10:10 AM
Could also be a broken lead inside the carriage housing.
I have seen that a couple of times.
Page 1 of 1 (6 items) | RSS
