Beoremote Halo can now control ML devices!
This post has 26 Replies | 2 Followers
beojeff
USA
Posts 2,012
beojeff Posted: Wed, Jan 5 2022 10:55 PM
After quite a few emails back and forth with B&O support and I suppose some assistance from Khimo, the Beoremote Halo can now finally control MasterLink devices that are connected via a BLC NL/ML Converter. The latest B&O app update now allows us to select NL/ML Converters as products to show up for control by the Halo.
This is amazing. Now, we can start a CD playing on the Beosound 9000 (even without speakers) and then JOIN that source from any other device using the Halo. We can also control playback using the Halo. This is a big step forward for full integration, but it's still not perfect yet. Here are the issues:
1. ML video sources via the NL/ML Converter still have the old basic control screen and not the new video control screen (with the four color buttons).
2. We still need a way to select which CD to play on the Beosound 9000. The basic control screen just lets us move back and forward between tracks.
3. Matrix sources do not appear in the sources.
Hopefully, it could be an easy fix for B&O to at least let us select the type of control screen to use so that we can choose to use the video control screen for those sources for which we need the extra control. Still, for me this is a joyous day!
beojeff
USA
Posts 2,012
beojeff replied on Wed, Jan 5 2022 11:36 PM
I feel like I'm being ungrateful in adding to my wish list. Yet.....:
1. We need to be able in the B&O app to change the order in which the devices appear on the Halo list. E.g., it makes more sense for the BeoSystem 4 to appear first on my living room Halo, but it makes more sense for my BeoVision 10 to appear first on my bedroom Halo.
2. For at least the BLC NL/ML and the BeoSystem 4, ALL sources are visible on the Halo -- even if we have those sources marked as hidden. We should be able to hide the sources we don't use. Also we should be able to change the order the sources appear on the Halo list.
Razlaw
Posts 4,345
Razlaw replied on Wed, Jan 5 2022 11:58 PM
This function requires a BLI, correct? And is it just audio sources, or for instance could it start music from a Core via a converter to speakers connected to a BV10?
Edit…..It works to turn on the audio sources through the BV10 without the BLI….just tried it….very cool. Now volume control of course. Would a BLI enable that?
beojeff
USA
Posts 2,012
beojeff replied on Thu, Jan 6 2022 12:10 AM
Razlaw:
Nope. This does not require a BLI. The BLC NL/ML converters are now recognized as devices the Halo can control and add to its list of devices.
My sources from my BeoSound Moment that are integrated with the BeoVision 10 via a BLC NL/ML converter are there, too! However, ALL sources show up, such as QPlay -- which is useless in the U.S. -- appear. Even though we have only certain sources selected on the NL/ML Converter to show up as available on NL, ALL sources still show up. This was similarly a problem with the BeoSystem 4.
beojeff
USA
Posts 2,012
beojeff replied on Thu, Jan 6 2022 12:13 AM
BTW, I had an earlier response from B&O support that it was IMPOSSIBLE to control the NL/ML Converter with the Halo. That person from support said that it was impossible because the NL/ML Converter had no sources. I replied and pointed out that it was the entire purpose of the NL/ML converter to make sources available on NL from the ML side.
Razlaw
Posts 4,345
Razlaw replied on Thu, Jan 6 2022 12:24 AM
beojeff:
Thanks! Tried it and it works. I guess it will only work for the Master Link device that is set as Master? And no ability to control volume, unfortunately. Would a BLI add volume control and/or ability to control ML products in two different rooms?
Also, and please forgive my lack of knowledge about the converter….I believe I could connect a pair of speakers directly to the converter? If I did that, would I be able to control those speakers with a Halo? Would it include volume for those two? Would I still have another option in the Halo to control the 1s connected to the 10 as I can now?
beojeff
USA
Posts 2,012
beojeff replied on Thu, Jan 6 2022 12:31 AM
Razlaw:
beojeff:
I tested and see that you're right: there's no volume control. For example, I can select a source on my BeoSystem 3 with connected speakers, but can't control the volume.
A separate NL/ML converter would be needed to make any former ML link room its own node on the NL system -- just like on the app.
AnalogPlanet
Vienna, Austria
Posts 678
beojeff:
Sounds great, only I cannot make the BLC NL/ML appear on the device list for Halo. Huh? It persistenly shows only the Stage (that it controls) and the A9 in the bedroom (that it doesn't currently).
Meanwhile, BLC NL/ML is normally present on my home network and the B&O app sees it, actually right now I am playing one CD via multiroom on my A9 controlled through the app. Really confusing. Big Smile But certainly looking forward to hearing more of your findouts Jeff while I try to make it work for me too. Thumbs Up
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Thu, Jan 6 2022 5:50 AM
AnalogPlanet:
Same over here............
until I chanced the setting of one of my BLC from ASlave to VMaster (and back). Suddenly they appeared!
the ML sources are shown, but not the BLC line in.
Note: with BLI I already have complete access within my setup.
AnalogPlanet
Vienna, Austria
Posts 678
In the meantime, I managed to fundamentally f**k up the BLC, after endless power offs, factory resets and other "tricks" while trying to make itself shown in the Halo devices list, now it is in endless green-led-blinking mode... well, update, moved to orange LOL. Which means bringing it to the service center one pf next days, hopefully they can get it to work again. Big Smile
Anyway, ontopic: that Halo/BLC/BLI combo seems to be expanding on usability and variety of creative ways to incorporate existing products and control and automate them. Wow, amazing, can't wait to see how it develops!
beojeff
USA
Posts 2,012
beojeff replied on Thu, Jan 6 2022 11:06 AM
The BLI solution has its purposes, but it's a very different approach using scene macros as triggers. However, I have a BeoVision 10 and two BeoSystem 3s that benefit from appearing as devices so that all of their sources can be listed. B&O will need to address the issue of the volume not being controlled and adding the full Beovision control screen, though.
TWG
Posts 1,672
TWG replied on Thu, Jan 6 2022 1:58 PM
Great news and move from B&O!
Thank you Bang & Olufsen!
Thank you, beojeff for spreading the good news. :-)
Razlaw
Posts 4,345
Razlaw replied on Thu, Jan 6 2022 2:03 PM
beojeff:
You have three ML products showing? I have three ML locations in my house but all I see in the app is the converter which does give me control of the Beosound 3000 but not of anything else.
Could you clarify what you see? And do you have multiple converters? Thanks!
beojeff
USA
Posts 2,012
beojeff replied on Thu, Jan 6 2022 2:14 PM
Razlaw:
beojeff:
Oh, Razlaw.... I have NINE NL/ML converters! All nine of them appear as available to be added to the list of controlled devices. There's a limit of only 10 devices that the Halo can control, though. So I have to choose appropriately.
I have converters for the following:
1. BeoVision 10 integrated with BeoSound Moment (bedroom)
2. BeoSystem 3 (kitchen)
3. BeoSystem 3 (den)
4. BeoSystem 4500 (dining room)
5. BeoSound 4 (dining room)
6. BeoSystem 2300 (bedroom)
7. BeoSystem 5500 (living room)
8. BeoSound 9000 (living room)
9. BeoCenter 2 & BeoSound 5 (living room)
Of these, I only had to do a power cycle on the converters for the BeoSound 4 and BeoSystem 4500 to get them dark black and not grey in the list of devices that could be added.
beojeff
USA
Posts 2,012
beojeff replied on Thu, Jan 6 2022 2:18 PM
@Razlaw-
I believe that you must have a separate NL/ML converter for each ML room -- just like for the B&O app if you want it controlled through the app. I no longer have any ML slave rooms.
Bw789
Posts 74
Bw789 replied on Thu, Jan 6 2022 2:36 PM
Great news!
Now if only NL/ML sources would show on my Beosound Stage via the App and BeoRemote One.....
Razlaw
Posts 4,345
Razlaw replied on Thu, Jan 6 2022 3:42 PM
beojeff:
@Razlaw-
Thanks!
Razlaw
Posts 4,345
Razlaw replied on Thu, Jan 6 2022 3:43 PM
beojeff:
What shows in the app? 9 converters or the individual ML products?
Razlaw
Posts 4,345
Razlaw replied on Thu, Jan 6 2022 3:44 PM
Also, what sort of control of the BS5 do you have in the app and by the Halo?
beojeff
USA
Posts 2,012
beojeff replied on Thu, Jan 6 2022 5:57 PM
@Razlaw-
The converters show up in the app. I've named the converters to correspond to the ML devices that are controlled.
Razlaw
Posts 4,345
Razlaw replied on Thu, Jan 6 2022 6:07 PM
beojeff:
@Razlaw-
Thanks!
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Thu, Jan 6 2022 6:17 PM
beojeff:
What do you mean with ML slave rooms?
Quite impressive 9 BLC!
My predominant system is NL/B&o ControlLink with 4 BLC all set as ASlaves with a total of 4 ML Audio systems connected 1 BS5 Encore and 1 BG4000.
So there are no speakers connected to any ML/older product. That way one have almost complete control of the ML Audio systems in the NL/B&o Controllink environment . As explained before I can choose the CD to play on a BS9000.
beojeff
USA
Posts 2,012
beojeff replied on Thu, Jan 6 2022 6:55 PM
Carolpa:
beojeff:
I no longer have any link room speakers or TVs that are part of an ML network. I.e., no Beolab 3500 or Beovision in slave mode that is reliant on a separate Audio or Video Master. All devices are now either natively NL or joined to NL via that device's dedicated NL/ML Converter.
Soren
Denmark
Posts 115
Soren replied on Thu, Jan 6 2022 8:26 PM
A question that relies more to you BLI and Masterlink products…. Do you still have full access to your ML through your NL/ML converters from your BLI in the same way as with MLGW
beojeff:
Carolpa:
beojeff:
AnalogPlanet
Vienna, Austria
Posts 678
Carolpa:
Worked for me too, thanks! Now I can join CD from BS9000 to Stage in multiroom, as beojeff described only with the Halo. I love it!
Carolpa:
Oh! So that means if I connect Beogram 4004 to a BLC line in it won't be controllable by Halo? Hopefully I can still multiroom it through the B&O app at least?
But would it show on Halo if I add BLI, despite the fact it is on BLC line in?
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Thu, Jan 13 2022 2:32 PM
AnalogPlanet:
for the moment only in combination with BLI
beojeff
USA
Posts 2,012
beojeff replied on Thu, Jan 13 2022 2:40 PM
You would have to create a macro in the BLI to make a new button for the line-in source.
I've sent an email to beocare pointing out to them some of these -- such as the lack of volume control and lack of the full video control screen.
Page 1 of 1 (27 items) | RSS
DigiCert Secured Site Seal
