Avant 75 mk2 issues
PJP
Sydney
Posts 1
PJP Posted: Sat, Jan 8 2022 10:23 PM
Hi all,
need help please with my Avant 75 that freezes up 5-10 times a year. Power down generally works, but once a year that fails as well!
it’s stuck again with centre speaker down/not retracted even with power off mode. Green light does come on but not much more on switching mains power on.
Remote seems to have lost all prior settings after holiday- drained battery.
Any suggestions appreciated.
pjp
andybandy
Posts 164
andybandy replied on Sun, Jan 9 2022 12:03 AM
I think you need a service technical man from B&O to lock on this. It can be your video engine that need to replace. But before that, you should reset the tv back to factory and also login to an google account. Remove apps that you never us on the android/google platform and use an Apple tv insead for all apps.
Thats my best tips :)
andybandy
Posts 164
andybandy replied on Sun, Jan 9 2022 12:04 AM
I think you need a service technical man from B&O to lock on this. It can be your video engine that need to replace. But before that, you should reset the tv back to factory and also login to an google account. Remove apps that you never us on the android/google platform and use an Apple tv instead for all apps.
expoman
Posts 182
Silver Member
expoman replied on Sun, Jan 9 2022 6:13 AM
The Avant must be logged into a google account to get software updates.  If this is not set up the TV will perform strangely.  Go into the settings and confirm this has been done. A number of  times this was skipped during the first time set up as it was thought to be optional. I would also check to see if you have the latest B&O software downloaded.
Page 1 of 1 (4 items) | RSS
